gp3000 help
power supply of amp is gone. whats your electrical like using 0/1 guage, high output alt etc.
if its the output board may be ****ed
AmpMedics
or db-r can fix, i has amp medics fix mine replace all outputs and output controller , i also have had one fixed by db-r,
http://www.db-r.com/
these are the only 2 guys i know that have the output control board if it needs to be replaced,
well hooked my MM up to the terminals and got a good readout so i checked the ohm load on my speaker wires, got nothing. Took my subs out and found a little prick of a wire that decided to tear itself out. So all is good but thanks for the help!
ok thats good, usually when u have no output and everything is correct, and no protect light it means the power supply is bad
stork90
stork90
Olmsted Falls Ohio
stork90
