got some questions for the well educated system people
kwitcherbichin
ok well i got a few questions about stereo mess
first off i see alot of people talkin bout active and some other shit, in simple terms what does active do or mean
this part is about subs
Electrical Q Value -Qes: 0.46
Mechanical Q Value -Qms: 3.29
Total Speaker Q Value -Qts: 0.404
Free Air Resonance -Fs: 21.00 Hz
Equivalent Compliance -Vas: 74.0 liters
One-Way, Linear Excursion -Xmax: 54 mm
Efficiency -SPL 1W/1m: 83.76 dB SPL
Effective Piston Area -Sd: 480 cm^2
DC Resistance -Re: 4.2 ohm
Nominal Impedance -Znom: Dual 2 ohm
Thermal Power Handling -Pe: 2000 W
Force Factor -Bl: 18.16
what does all that mean =/ or what r the things that i need to worry about cause doesnt the way the sub is built effects the box?
well if u can answer these questions please do and thnx
http://www.caraudio.com/forum/showthread.php?t=146726
http://en.wikipedia.org/wiki/Thiele/Small
http://www.the12volt.com/caraudio/thiele.asp
http://sound.westhost.com/tsp.htm
kwitcherbichin
kwitcherbichin
stantonsburg, nc
perfecxionX
