got a question about how coils fry...
so even if you used a different materal in the coil it would still be the weak link because theres so much wraped up so close with nothing to cool??
There is a good bit of cooling in most well designed speakers, both active (air cooling) and passive (large chunks of steel for the heat to be soaked up into to be then radiated into the environment, the basket itself also acts as a heat-sink once the top plate is hot enough to transfer heat to it). The coil simply has more resistance than the speaker wire or the tinsel leads, therefore it is heated more.
TrlcKed_OuT
TrlcKed_OuT
las Vegas
sundownz
michigan born
    May 14, 2026
michigan born
    May 14, 2026
