mmats juggernaut
ultimate157
Engineering Student
Was there a standard coil configuration for the 6-spoke juggernauts? I'm looking at picking up an 18" but the guy doesn't say what the VC's are.
According to MMATs, the current generation (12-spoke) is dual 2's with a 1500wrms power handling.
Actually, a complete spec list would help greatly //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
if its so small how can it handle 1.5kw? whats the diameter?
3" coil...
The cooling holes in the top plate help it a good bit..if it was just a regular plate the coil would probably burn up around 800 watts...
If i had one here with me i'd show it to you but i'm about 120 miles from a recone that i built up for the jugg...
They come stock as dual 2's with a 4 layer roundwire coil 32mm long...tiny coil
how do u know its 32mm? Did you recone a newer jugg. I only ask cuz mine were wound longer than that at dual 1.4s at least from what i remember
The ones that were made by Resonance originally and the series right after Mmats left them as a buildhouse were dual 2ohm 32mm long...i haven't touched a new one.
I've got the soft parts sitting beside me...and a set of calipers //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif.
ultimate157
Engineering Student
ultimate157
Worcester, ma
sandbags
vegang
vegang
