got a couple of db drag questions
No removing the seat, it can be folded. But the install cannot affect the normal intended use of the vehicle. The box has to be in the hatch area and the rear seat needs to be able to fold up and down like it was intended. You can leave it folded down for competition.//content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif The big boys in street a are doing 153+. A Yaris will be a very good street a vehicle and will do well locally but the CRX's rule street a and b. Street C is a split between Explorers and Crx's.
crx's still have the advantage in street c. loudest explorer certified i think was 157.1. thats why there is street stock, no crx's //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Thanks for clarification, It is pretty bad when when we need a class that excludes the CRX, just shows the inherit advantages they have over other cars.
In Street A my yaris is doing 153.6 with two 9510's and one stetsom 7kd and a single stinger 1700. If you want a killer music/spl box for the Yaris do a box that is 4cubic feet for two 10's with two 6" aeroports. Subs facing driver side and ports facing passenger. Approximate dimensions external are 28"x23"x14" length x width x height. The two 23"x14" sides is where you mount the subs and port. That will give you 4.12cubic feet. With the right subs and about 2000w of real music power it will easily do almost 150db for music. And probably close to 151 pure spl. This is not a pure spl box but is loud as snot and will sound really good if you like tight bass. It won't hit the crazy low below 38hz great if you like that kind of bass. But it will still sound good.
And as for if you want to make is a crazy spl car for street A or B you don't need a crx anymore. The Yaris has just as much potential if you want to put the time into it. I have hardly tested my car and I'm off of the loudest street A CRX by .7db.
kurrupt
hustlenomics
kurrupt
neenah,wi
dtbrown
    Jun 20, 2026
    Jun 20, 2026
