Good subs for kicker panels?
unless you can vent the driver to the outside of the car and run it IB, which is fairly impractical you will have almost zero low-end extension and terrible efficiency...
The room inside kickpanels is inadequate for most midranges...let alone midbass...and definetley not sub-bass.
It seems pointless to me, and a waste of time
Why not run a pair of Peerless XLS 8s or Dayton RS225s in your doors IB and cross the subs @ 50hz?
bass is omnidirectional...so staging shouldnt be an issue. You shouldnt be able to detect the subwoofer unless its creating some pretty nasty harmonics (in which case...GET A NEW SUBWOOFER)
unless you can vent the driver to the outside of the car and run it IB, which is fairly impractical you will have almost zero low-end extension and terrible efficiency...The room inside kickpanels is inadequate for most midranges...let alone midbass...and definetley not sub-bass.
There are other ways to do it rather than IB. It all comes down to how hard you are willing to work to get what you want. Fiberglass, expanding foam and the large void in the fender can do amazing things.
If you can achieve a QTC between .5 and .7 than its viable
If it was an easy install than I might be able to justify something like that, but I dont see any true benefits of installing the subwoofer in front of you that cant be achieved by other means.
Many people have done it with great results (see previously linked install for an example).
Many people have done it improperly with bad results.
It can work, if you're willing to put the effort into it.
a QTC between .5 and .7 equates to the fastest (least group delay, best transient response) and flattest frequency response
If you cant achieve that, you're making too many compromises. A nice set of 8s run IB with a properly integrated trunk subwoofer (running a subwoofer infinite baffle on the rear deck would be a better project than placing it up front)
bangman
bangman
Norristown, PA
thadman
