Good sub in an enclosure that's 2.5 cu. ft. @ 38 hz
Not it is NOT the same buildhouse. This is not the equivalent. It has the same basket. That's it... Compare magnet weight + overall weight of this sub versus the DD9500, AQ HDC3, AB HD, and of course the Konaki. You can visibly tell the magnet is much smaller and all the others have a total weight of 50-60+ LBS while the Cadence comes in at 35. The basket and 3" coil are the only similarities they share...
Too spendy, forgot to tell a budget. I'd like to spend less than 200 and have it be dual 4 ohm vc
Read the full description of that sub and it looks promising. Based on the parts they used alone, 120 bucks is a STEAL. It also appears the builder is quite knowledgeable. I would look into that sub. You said your price was under 200 and has to be D4. I think that's your ticket...
hd uses a 300oz magnet different magnet
406oz for the 9500
and hdc uses 340oz magnet
cadence uses a 270oz magnet
cadence uses a single coil for higher efficiency
their are of course little differences but their all the same buildhouse and amazing quality
Cadence DCX12-1500-2 Subwoofers - Car Subwoofers at Onlinecarstereo.com
this would be the exact hdc3
Cadence ZRS12-600D4 Subwoofers - Car Subwoofers at Onlinecarstereo.com
sdhc2.5
//content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif same buildhouse
http://www.onlinecarstereo.com/CarAudio/p_20805_Cadence_ZRS12-1000-2.aspx
zrs is in between the 2 and for 179 dollars is a steal, so is the tc sound hybrid. those are the 2 id get if i was u
comes with a 1 year warranty, yea dd is good but let me tell u warranties only cover if it was defective, burnt coils, spiders etc all the things that happen to subs are not covered very rarely do i see coverage, then u need to have equipment installed by certified installers of the company etc.
Warranty is the industry standard 1 year type against defects in workmanship and materials. The warranty NEVER covers abuse which can show up as a burned or charred tinsel lead, voice coil or even the awesome crushed former 'defect'. Shipping is your responsibility. If your sub does indeed have a defect return it in it's original packing and we'll repair or replace your sub. We'll pick up the tab to send it to you as well.
MONSONwarrior
Premium Member
Constantly Rebuilding...
MONSONwarrior
Baton Rouge, LA
mclerico83
