Alpine mrp m500 and JL Audio 10W3V2-D2
Can anybody help me please??? I also want to know what type of enclosure is best for this sub? And should I hook it up as a 2ohm load or a 4ohm?? Any help will be greatly appreciated!!!
Not a lot of love for JL here and that is a model that wasn't around very long I believe. The w3v3 has been out a while. I doubt the alpine can go to 1 ohm without going into protection mode. So with 1 sub you are looking at a 4 ohm load. Bottom pic Subwoofer Wiring Diagrams, One 2 ohm Dual Voice Coil (DVC) Speaker So it looks like you will be sending 300 to it which is what JL has as their rms. http://mobile.jlaudio.com/pdfs/10W3v2_MAN.pdf They always recommend too small of a box. .75 sealed and 1.25 ported would be a good start. Play around with winisd and see what works best. LinearTeam On amp settings you may try searching for setting gain or something along those lines. I set by ear so can't help you there.
Good Luck
The sub is a dual 2ohm voice coil. And why no love for jl audio? I think they are great subs just a little overpriced.... Well thanks alot for the info, I really appreciate it guys. I have it in a sealed box right now but it sounds like air leaks out when I turn the volume up.... N I feel like the box is 2 small. What do u guys think about polyfill? Should I use any??
If a guy likes his sub and is willing to pay whatever for it, who cares what others think? You will find that guys love whatever is in and piss on the rest. I don't know how many times I hear of sundown amps being recommended for sq. They never do well in sq competition and are known for being noisy. That doesn't stop the guy who runs them from suggesting them for sq. Always hear guys trashing w7 but have yet to hear of a logical suggestion for a replacement sql sub that is better. Seems a lot of folks parrot whatever they hear without fact to back it up, and usually no experience in the matter as well. Personally I don't like the sound of w3, but if you do who cares? You are not buying your stuff to appease me. All that matters is it fits your listening style and you are happy with it. Yes on the polyfil, but get your air leaks sealed most importantly.
Good luck.
Thanks a lot for ur help. I went out n got a sealed box that has .75 cubic air space in it, also went out n got a pound of polyfill.... I used half of it. Is that too much? Can u put too much in? It sounds like the bass is too tight...... Also what setting should I set my low pass filter to for that sub?
Low pass at 80 hz is good for most installs. You can go lower if needed. Personally I like 80 myself. Sub Box Polyester Fiberfill .5 lbs-.8 lbs should be about right. I use w7 in most of my vehicle and go 1.25 lbs per cube. A lot of people use 1-1. Read the net weight on the package and adjust from there.
Your sub should displace around .05 so .7 should be your internal volume which is perfect. W3v2 do sound a little tight. Hard to describe sound but they sound a little higher than the hz they are reproducing. You can try placing about 5 inches from the hatch/trunk of the vehicle with the sub facing the back. It will give you more output to boot. If it does not clear up the high sound, you can cut the crossover a little more. Make sure your bass boost is at 0 db as well.
Ok I had the bass boost up about half way... I'll turn it all the way down, so then I should turn up the gain right? The bag of poly fill was 16oz which is a pound, and I used half. Does that sound like enough or too much? I don't know man, I'm thinking about selling this sub n getting the w3v3-2 n just wire it at 2ohms to get the full power of the amp. What do you think? Will the same box be ok for that sub?
Yes you will most likely have to raise the gain with the bass boost down to get back to the output you were at.
You are using .5 lbs, sounds about right to me. Also take it out and try without before you toss the sub.
I am sorry, I really can't give you an opinion on the 10w3v3. I was a JL dealer and still don't like them. They are an improvement over the v2. Neither is a terrible sub by any means. Just not the best out there for the money. .7 sealed will be good for most 10's out there.
What are you looking for? Sound quality? SPL? Or something in the middle? What kind of music do you listen to? May be able to get this one in line with what you need. If not as you said sell and start a new thread on recommendations.
Good Luck
I want both, good sound n spl without breaking the bank n taking up all of my trunk. I generally listen to everything except country. Right now I'm listening more to heavy metal n rock. A little of hip hop n rap n reggae. Also will a stiffening cap help?
Don't waste the money on a cap. They are a lot of hype. You are really not running enough wattage to worry with any electrical system upgrade as long as your car is 90's or newer. W3 should not be bad for what you are listening to. If after trying different placements and settings you are not satisfied you may want to start a new thread on suggestions. An upgrade to a v3 would be an eclipse 6010 for $100. If you need even more spl maybe an re sx10, not sxx. Personally I would try to get the most out of what I already had before giving up on it. If it doesn't meet your standards sell and get what does.
Thanks, I'll keep trying different things to see if I can get it to where I like it. So no cap, even if all my lights dim at night when the bass hits? I'm driving a 95 Mazda Millenia S. I looked at the specs for the 10w3v3 n it says it's continuous at 500 watts but on the chart it says it's optimum power was 300 watts, I don't get it? I think I'll also start another thread just to get some ideas. Thanks alot for your help, it really helped me out. Also one last question, why shouldn't I use the bass boost on my amp?
P_diaz82
P_diaz82
Oxnard CA
P_diaz82
