Good Combo? need quick answer!
BigSquid10
k my amp im looking at is a i plan on a 2ohm set up i just wanted to know if the amp isnt too much for the kicker l7
Pioneer GM-D510M 1000Watt Class D Mono Car Amplifier
Power: 1000 Watts x 1 @ 2 Ohms
Power: 600 Watts RMS x 1 @ 2 Ohms
Power: 300 Watts RMS x 1 @ 4 Ohms
Hi-Volt Input
Selectable Crossover (40-240 Hz, -24dB LPF)
Oversized Power Terminal
Screw Type Speaker Terminals
Gold RCA Inputs
Variable Bass Level Control
And my sub is a 2006 KICKER S12L7 12" SUBWOOFER
Item Specs:
- SOLOBARIC SUB
- 1200W PEAK POWER
- 750W RMS
- DUAL 4
- SQUARE CONE DESIGN
- WIRE TO A 2 OR 8 OHM LOAD
Ha ha since its a Pioneer amp its A ok for this setup..
Just read the gain tut. and use common sense..
//content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
i thought that pioneer was good would a alpine amp be better? what amp would u suggest then some somewhere under 250 and i get stuff on ebay so i could get it cheap. about a ported box i drive a 97 mustang and the trunk opening is really small a 13" box would fit but dunno bout anything bigger.
ok just got done looking and found a rockford amp there know to be good. see if this amp is aight. i can get it for 225 so thats around my price range is this one better than the pioneer one?
ROCKFORD FOSGATE RF X6 850w RMS MONO CAR AMP AMPLIFIER
THIS AMP IS AN Ultra high performance, high technology amplifier
Variable Low Pass 24dB Crossovers
RemotE Punch Bass (INCLUDED)
Switchable 24dB Subsonic Filter
Subsonic Filter
Bass Control
Fan Cooled
RMS Power 1x425Watts
Power at 2 Ohms 1x850Watts
Bass Boost 0-18dB
Bass Boost Frequency 45Hz
Channel Operation 1
Signal-to-Noise 90dB
Frequency Response 20-22KHz
Adjustable Crossover Y
LED Power Indicator
ok i finally ordered all my shitt so this is it now with the amp. after reading the fourms i think i should of got a more powerfull one but not sure.
Sub: 2006 KICKER S12L7 4 ohm 750 watts rms 1200 peak
Amp: INFINITY REFERENCE 611A 657 Watts RMS @ 2 ohms 761 watt sdynamic power. ( ill have this turned all the way up)
Box: Kicker L7 PORTED ENCLOSURE
Wire: 4 gauge with 60 amp fuse
You better get reading all over, have someone else hook it up or be prepared to buy new stuff soon //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif. Properly done, it could get pretty loud. Prolly spent more on the infinity than it was worth...but its all good //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif.
spent 210 on amp of ebay brand new. so if i have it turned up loud i can blow my sub or amp?
BigSquid10
BigSquid10
Delaware
BigSquid10
