good alternator to some jl audio and kicker amps??
importtuner
ny
hey i got 2 1000/1 amps by jl and a kicker kx800.4 and i need some help wid my alternator as its dying painfully after every bass note off my 2 13w7's. i got a 1998 eclipse gs and i was wondering if any of you know of a really high ampeare alternator.
by the way how is the denso alternators i was thinking of that. thanks for the suggestions
You need extra optima battery's ............
With a sufficient alt the batteries are only going to come into play if he listens w/the engine off a lot. If the alt is INsufficient extra batteries will only prolong an inevitable death.
Stinger has a 12V 300A alternator is is very expensive. Has a cooling system, all computer controlled
P.S
has any body on here bought an alt from excessive amperage for a gm/ chevy truck.
stinger is very expensive...try excessive amperage or look around on the forum for more posts on this, I myself have made a recent thread with others chiming in...some good posts for alternative to spending a lot of loot at the local audio store for an alternator that only does 140 amps
Hello I also have a question I want to buy 160ah lto, i.e. 4 banks but I have a stock alternator of 140 a and a maximum load of 14.9 do you think...
Okay cool bc I'm thinking about getting 5k amp and just wasn't sure if that battery would do but I appreciate all the help
18
I don't have one...but I check my voltage with a dmm once a week or so
12
987
You just found your own solution. Move the DSP elsewhere. The RCA is triple protected but not the RCA plugs. I do not know if there is a mesh or...
importtuner
importtuner
ny
KARLEON
Doxquzme
    Jun 1, 2024
1aespinoza
    May 31, 2024
