Going with active crossovers....
excluesiveonez
looking to go with an active xover setup but im having some difficulties
my goal is to have my:
midbass play from 80hz-400
midrange play from 400-3500
tweeters play from 3500 and up.
the mid bass will be on a 2 channel amp
the mids and tweeters will be on a 4 channel amp
can anyone suggest to me how i should go about getting the frequencies i want to each speaker. can anyone point me in the right direction for the correct product to go with and how i should use it?
Do you have a budget for an active xover?
You could use a Profile RX30R ($40) or Memphis 16-XO3 ($130). Both are 3-way and meant for sub integration, but that can be easily worked around.
Here's the spec sheet for the 16-XO3.
Here's what you can do for a 3-way setup as you described:
MidBass: Use the Xover sub output set to 400Hz LP....set your amplifer for this output to HP 80Hz.
MidRange: Use the Xover Bandpass output set to HP 400 Hz, LP 3500 Hz....keep amplifer for this output on full range.
Tweeters: Use the Xover High output set to 3500 Hz....keep amplifer for this output on full range.
Do you have plans to add a separate subwoofer xover or is that going to be run controlled through you HU/sub amp?
so basically what i need in addition to what i already stated is..
an additonal 2 crossover points for the rear:
midrange crossed at 400
and tweeters crossed at 3500
these mids and tweeters will be on an additional 4 channel amp
as well as a channel for the subs...
all in all
i neet 6 channels up front, 4 in the back and a sub channel...
so if someone can build on what deja posted to make this all work, i'd love ya. i understand that there will be a combination of products, but that does not scare me!
ok...
the dlq-8 will integrate, and give me 8 channels.... then where do i go?
how do i then split the front to a three way and get the xover points that i want with no overlapping, and get the rears the same way
nah this is for me...
im going the pro-audio route, which u guys would probably hate
front:
2-8" o2 audio midbass
2-6.5" o2 audio midrange
2-o2 audio tweeters
rear:
4-6.5" o2 audio midrange
2-o2 audio tweeters
i dont want to lose the fading (front to rear) option becuase i dont want to lose all imaging, most of the time i will keep it 75f/25r, but at times i want to pump it up a little bit, to go 50/50 and have a bunch of vocals.
A combo of the DQL-8 and active crossover(s) would do the job.
Just so I'm on the same page as you, you're wanting to do the following, correct?
FRONT
2 channel stereo MidBass: 80-400 Hz
2 channel stereo MidRange: 400-3500 Hz
2 channel stereo High: 3500+ Hz
(6 channel XOVER)
REAR
(4 or 6 channel XOVER)
SUB
1 or 2 channel mono up to 80Hz
(2 or Sub channel XOVER)
Correct?
2 channel stereo MidRange: 400-3500 Hz2 channel stereo MidRange: 400-3500 Hz
all is right except that this may cause confusion...
the midrange speakers are 8 ohms, so i was going to wire them in parallel to get me a 4 ohm load on the amp for each channel. i doubt that this will affect much, and it will probably be 2way in the rear if I understand how the xovers work.
that altomobile xover looked really sweet but i bet it costs a fortune, looking for prices now
deja... ur the man, hopefully u can make this work for me (and hpefully i dont sound like a noob, just the oem interfacing combined with going 3 way is confusing me)
80... ill be waiting for the call
i cant wait for the ms8 to come out, that would support the 4 way setup, but still would be assed out for the front to rear fading aspect
but it sums the frequencies, im not sure if all the others do that... i may go with the PXE-H650 when it releases, or buy a flying pig.... whichever comes first
excluesiveonez
excluesiveonez
ELMHURST
excluesiveonez
