Looking at the owners manuel right now and the Fronts are for the mids Rear is for the high range.also underneath the deck there is a switch for 3 way or F/R Sub.Be careful dont want to Ruin your comps.Edit: Just checked the back of my unit, The top is labled front, middle rear and bottom sub(I guess like all other HU's) But their is no mention to if front is associated with "Tweeter", but I will take your word for it.
SO I will connect The Tweeter to the front RCA's the Mids to the rear RCA's and the subs to the well sub RCA.
Now I assume their is a certain setting inside of the 9887 to "turn on" this active setup?
Thats wierd I checked out the manual and it does say, highs (Rear), mids (Front). Funny thing is my 9835 is the opposite of that. Why wouldnt they leave it the same.Looking at the owners manuel right now and the Fronts are for the mids Rear is for the high range.also underneath the deck there is a switch for 3 way or F/R Sub.Be careful dont want to Ruin your comps.
This is the correct way. Trust me. disconnect your rcas from the rear of the headunit.for my 9887 i have it connected like this.
front - mids
rear- tweets
sub - sub
You're right this is the only alpine unit (9887) that I have seen this way. All the others are the way you describe.Thats wierd I checked out the manual and it does say, highs (Rear), mids (Front). Funny thing is my 9835 is the opposite of that. Why wouldnt they leave it the same.
Well right now I have the old harness connected, seemed to turn on fine. The Older harness was pretty well taped in their. If I absolutely need to switch it I will do so.Yes turn filters off from the amps, are you sure you have the rca's connected correctly? Did you swap the harnesses? You need to put in that 9887 harness, yes it will work with the other harness, but you should be using the 9887 harness.
Right now I have it connected like the following:Looking at the owners manuel right now and the Fronts are for the mids Rear is for the high range.also underneath the deck there is a switch for 3 way or F/R Sub.Be careful dont want to Ruin your comps.
Got it.You're right this is the only alpine unit (9887) that I have seen this way. All the others are the way you describe.My 9833 was this way, but for some reason it has changed for the 9887.
Trust me
Rear - tweeters
front - Mids
sub - sub
