Glue on solder points..
bgordon
160db bound !!!
I know it sounds crazy but some subs have glue over the solder points that connect the tinsel leads to the voice coil. Anyone know of any good glue brands that would work? Would gorilla glue work? I have used gorilla glue on spiders and subwoofer surrounds that I have dropped in baskets before. Any help is appreciated thanks.
Bruce
Please don't use gorilla glue it won't hold up to abuse. If you don't use ca glue use some loctite 5 min epoxy at least. Noticed last night my zv4 also has glue all over the tinsels.
You think any epoxy would be ok? Can't find ca glue here
They don't sell super-glue in KY??? F*ck me, you guys are backwards.
Seriously, though CA glue is best because it is rigid and will prevent the lead from flexing and breaking AND it can be dissolved with acetone if you ever need to get it off for some reason.
bgordon
160db bound !!!
bgordon
Central Kentucky
CrossoverOre
ThxOne
    May 13, 2026
ThxOne
    May 13, 2026
