getting two different battery readings help plz!!
  • 6
There's a break in the connection somewhere the rear battery is simply not connected OR your grounding point does not work, move it.
Clearly the rear battery is connected if it's dropping.
Belt slip would make both read low because the alt would not put out what it should. A water pump has nothing to do with this. Something you messed with while doing the water pump is the issue. Sounds like a lot of resistance somewhere (ground?), or a bad battery.
692
Appreciate the input! I'll check out the calc site and see how it compares. I'm in the beginning stages of building the box. Unfortunately with...
956
Anything worth getting is always worth it more at a steep discount. Not familiar with that unit, but the brand is great.
I'm putting 2 under my rear seats with 2 passive radiators. Only a 3kw amp. Only reason I'm selling my adire subs before even trying them. Granted...
20
I'm stupid. Please repeat what stupid me said that was wrong.
17
rob_956
rob_956
laredo tx
jco1385
Decebal
    Jun 10, 2024
Decebal
    Jun 10, 2024
