getting two different battery readings help plz!!
Belt slip would make both read low because the alt would not put out what it should. A water pump has nothing to do with this. Something you messed with while doing the water pump is the issue. Sounds like a lot of resistance somewhere (ground?), or a bad battery.
rob_956
rob_956
laredo tx
jco1385
ThxOne
    May 13, 2026
