getting some work on the saturn done- take a look! *not 56k friendly!*
req
am a mod.
so im going to have an SQ install. wich inclueds the strict wire stuff - like clean, strong, and shielded connections, ect ect.
last night, i messed around with that little fuseblock i bought from http://www.allelectronics.com (where i got mad split loom and heatshrink for CHEAP as well) and i grinded the PCB so the copper trace was split in half, so i got 5 channels for my fused remote wire distrobution block, and 7 channels for my fused accessory power distrobution block. uses 12 individual ATC blade fuses, and has 6 10 awg inputs and one 10+ awg quick connect for the rem side. i cant wait to use this baby.
so i got my bumper on, my fender on, and the new clear marker lights. i mounted my fuse, i did the alt and batt re-grounds (gotta remove the tire to acess the alternator +, so ill wait on that one till this week. i shielded all the engine 0awg with split loom, and periodocially put heatshrink wrap around it, beginning, middle, and ends. i crimped my 0awg terminals with a 5lb hammer, vice, and channel lock pliers. grinded the paint off the mounting locations (upper front strut mounts) and i did a few other misc things today. all-in-all lots of small things that needed to be done.
now im gonna go put the sideskirts on, and remove 2 sets of 16 foot RCA's i dont need
then ill find somthing else to do - or call it a day until friday.
and it is about 95 degrees here - hot as **** - i was leaking like a freakin sprinkler the whole tiem, and my shirt is soaked with sweat
and as you all well know - i dont post a thread like this without pics - so without further adoo - here they are
the fuseblock: before
the fuseblock: after
new bumper installed (old was was TORN UP)
new fender, again, old was was broken to bits
[continued!]
new clear markers - look great IMO - specially for $15 shipped
the 200amp anl 0awg fuseblock i got from FRITO (great seller!) for like $10
mounted SNUG - dosnt move at all. that metal strap is like a Z shape, and selftapping screws were used. i think im gonna paint the top part with some black sealant stuff
closeup of the connection, screwed in with the allen bolt, then shielded with the splitloom, and the heatshrink goes all the way onto the actual fuseblock, and the wire to hold it on way better (brownie points from the judges i hope)
here is my alternator ground. nice and solid, and shielded like woah
and my battery ground, again - shielded like the rest, and solid as a rock.
comments? questions, FEEL FREE!
looking good just hope that fuse block can handle all that power
like i said in AIM - its just for a couple ampres for the processors\lights and the other side is strictly for the REM turnon (off the relay)
there will be a seperate fuseblock 0awg->four 4awg with appropriate fuses for the power to the amplifiers //content.invisioncic.com/y282845/emoticons/naughty.gif.94359f346c0f1259df8038d60b41863e.gif
you should sound deadon all the parts of your car before you put them all back together. that would be super sweet
SHHHH! i just got a gallon of spectrumV2 yesterday //content.invisioncic.com/y282845/emoticons/uhoh.gif.c07307dd22ee7e63e22fc8e9c614d1fd.gif
req, that little PCB idea is awesome. I may have to steal it from you. Looking awesome so far, can't wait to see the rest of the project come together.
go for it //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
i posted the idea for all to use //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
just needs a little modding for my purposes! //content.invisioncic.com/y282845/emoticons/naughty.gif.94359f346c0f1259df8038d60b41863e.gif
just wait and see what i do with it //content.invisioncic.com/y282845/emoticons/noevil.gif.0723d47b61c306c6d554fb6555014096.gif
OFF TO GO SHOPPIN!
ill be back in a few hours i think //content.invisioncic.com/y282845/emoticons/veryhappy.gif.fec4fed33b4a1279cf10bdd45a039dae.gif
req
am a mod.
req
Syracuse, NY
req
