Gain Question
AndonD454
The Wistles Go WOOOOOO!
if i wanted to set a hifonics bx1605d for about 1200 wrms @ 1ohm , id set the voltage to ~35 correct? heres the problem: what if the amp wont put out that much power? if the amp will only give me 1000 wrms, then by settign it to 35 volts in an attempt to get 1200 id most likely be clipping the amp right?
That is the same thoughts I have on setting gains with a DMM. If an amp will not do it's rated power cleanly you will most likely be clipping the signal. On the other hand if you have an amp that exceeds it's rated rms specs you will not be using the amp to it's full potential. True??
i usually just turn the gain down a little from the voltage to be safe. also if your playing music you won't be maxing out your amp like you would using a test tone or something. just do the gain tutorial and lower the gain a little bit below the voltage to be safe.
You can get close with tones, but music signal is all OVER the place in both frequencies and voltages. Like, if you listen to rap, the bass line...
848
I hold firm on the deposit in all situations 😎
  • Locked
I dont see a Username and date on any of these pics that the FOR SALE Rules Should Apply. Are these pics off Ebay?? Place those with the pics so...
AndonD454
AndonD454
Toledo/Columbus, OH
DBfan187
