AndonD454
The Wistles Go WOOOOOO!
if i wanted to set a hifonics bx1605d for about 1200 wrms @ 1ohm , id set the voltage to ~35 correct? heres the problem: what if the amp wont put out that much power? if the amp will only give me 1000 wrms, then by settign it to 35 volts in an attempt to get 1200 id most likely be clipping the amp right?
