Gain, Output, and Thermal Damage
idiot
I have a gain-setting question. It’ll probably show my inexperience, but better safe than sorry…
I’m running a sealed RL-p15 (~2.2 ft^3), powered by an Avionixx 1200.2. Using the sqrt(P*R) formula and a multimeter, I tried to set the gain to output only ~800W (sqrt(4*800) = 56.6V). The problem is that this is not loud enough at normal listening levels. The cone moves very little, even on sine waves below 35Hz.
When I set the gains for both my component amp and the Avionixx, my head unit (RF 8250) was set to volume level 26, and a level of 16-18 is normally as loud as I take most music. At this level, I don’t feel that the sub has enough presence, and it barely moves but on the lowest of notes. To test higher output, I brought my head unit up to 26 (which would theoretically correspond to ~800W from the amp, right?). This is the kind of output I was seeking for daily use. But even at this level, the sub doesn’t come close to reaching its mechanical limits, even on low notes, and I know that it can play much louder.
But I’m not really sure what to do, since I don’t want to be in danger of thermal damage. My amp is capable of putting out 1200W, but I don’t think it should be necessary to dump that much power in order to attain maximum excursion from my current setup. Any thoughts?
Bass boost is disabled, and I've set the crossover properly (switching it to full-pass solves nothing). Those are the only settings it has.
Every other tutorial I’ve read wants me to set the head unit around the 2/3 mark, to estimate the nonclipped HU range. This method is incorrect?
As for the Punch Bass setting… I’m using the Denford unit, which doesn’t have this.
Well, I readjusted the gains per your recommendation, and everything seems better. I’ll have to give it a longer drive tonight to really see, though. I also bumped the power up a bit, since Mike is now recommending 800-1200W on his forums, for various size enclosures. So I don’t think that a thermal problem should arise from the 900-1000W I’m sending it.
Before I messed with anything, I tested the voltage at volume level 20 (when I had previously set the max at 26), and I was only seeing 13.6V. So that may very well have been my problem. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
idiot
idiot
Connecticut
idiot
Doxquzme
    Jun 18, 2026
Doxquzme
    Jun 18, 2026
