gain all the way up but no distortion or clipping?
  • 4
How are you testing for distortion?
by ear.
i turned my head unit 3/4 of the way up and then played this 40hz test. then i went to the back and turned my gain up slowly waiting to hear some distortion but there was none. so now i have it set at the max input level.
by ear.
I wouldn't trust your ears.
Most likely your HU isn't putting out its max signal power to the RCAs. Therefore you can turn the gain all the way up.
Turn the gain down. I give myself temporary partial hearing loss by setting the gain with a test tone and the sub hooked up, so your hearing is getting saturated. It's safer to set the gain with the sub disconnected and an oscilloscope to monitor the waveform, but you can settle for the DMM method and get it half-assed tuned.
Subs play to the beat with gain low but if I turn it up my subs play loud unwanted never ending bass that is constant and wont stop until I turn...
You have a blown cap in the amp more than likely. Had the same thing happen to a soundstream amp.
You can get close with tones, but music signal is all OVER the place in both frequencies and voltages. Like, if you listen to rap, the bass line...
913
I hold firm on the deposit in all situations 😎
twofournineseve
twofournineseve
United States
trumpet
Decebal
    Jun 10, 2024
