Fusion active sub wiring help
Twixx
Hey guys,
I just picked up an old Fusion en-at1100 active tube.
21710
21711
It didn't come with the wiring plug so I'm having to figure it out myself. I'm pretty sure I've found the 6 pin plug at a local electronics store but will need to sure the plug appropriately. My main question is, how do I wire 2 thinner power wires and ground wires to suit 8 or 10 gauge wires for the power/ground? I'm not 100% sure how thick of a wire I can get into the plug, will hopefully get my hands on it tomorrow to have a better look.
Also bring a 300w RMS amp would 10g be ok or should I be looking at 8g? I'm concerned if I go 8g I'll have more trouble mating the wires together.
Hopefully I can get this figured out so I can get it installed by the weekend. Cheers all
I had an old fusion sub a few years back. the plug is a 6 pin pc power supply connector.
you can get em on newegg pre wired pretty cheap ->here <-
just strip the two wires about an inch away from the 6 pin on the 12v and ground side. and tie them into whatever gauge wire you would normally use for that amount of wattage.
I had it for years and never had a problem.
I was thinking the cost verses the price of a new subwoofer wouldnt be worth the effort. Fusion Audio wasnt a very well made brand of audio in general
It is in eBay. It is a bit more complicated. You clip off the gray blocks on your radio's harness and splice in the new harness by color matching...
Well I finally had a chance to hook up the us acoustics amp. What a difference. Still playing around with the 13 band equilizer. The h/u put out...
10
559
10
951
Twixx
Twixx
Adelaide, Australia
devin171moto
    May 18, 2024
    May 18, 2024
