Fuses and fuse holders
lol i know how to wire it up was just looking for a decent fuse holder.. that im not going to get ***** on im going to need atleast 4 so thats like 100 right there //content.invisioncic.com/y282845/emoticons/wow.gif.23d729408e9177caa2a0ed6a2ba6588e.gif
not all amps are internally fused //content.invisioncic.com/y282845/emoticons/fyi.gif.9f1f679348da7204ce960cfc74bca8e0.gif
just an //content.invisioncic.com/y282845/emoticons/fyi.gif.9f1f679348da7204ce960cfc74bca8e0.gif
yea, I just been schooled. I never delt with one that wasnt so didnt know that there were some that wasnt. sorry again for wrong info..
the waffer ones that I showed you from parts express are good. and they use ring terminls wich for me is more secure then the wire being held down by the screw
25 bucks for a fuse holder is a little outrageous lolthought you go buy how much power your going to be running? i just went by this..
Rated power output
----RMS power, 2 ohm linkable/dual mono
6000W x 1CH
----RMS power, 1 ohm mono
3000W x 1CH
----RMS power, 2 ohm mono 1600W x 1CH
----RMS power, 4 ohm mono
800W x 1CH
Signal to Noise Ratio >90dB
Low pass frequency crossover 35Hz~300Hz
Subsonic filter 10Hz~60Hz
Bass boost @ 45Hz 0~18dB
Phase shift control 0~180 degree
Frequency response 10Hz~350Hz (+/- 1dB)
T.H.D @ 4 ohm
Efficiency @ 4 ohm 86%
Fuse rating 300A (external type fuse)
Input Sensitivity 200mV to 6V (+/- 5%)
Dimensions 252(W) x 53(H) x 594(L)mm
Yes that is really high for an ANL fuse holder.
Knu $20
Scosche $7
Those are the two extremes that I would recommend. The Knu unit is very high quality and the most I would ever spend. It should be easy to install and water tight as well.
The Scosche is a bottom of the barrel, bare-bones fuse holder. You will need ring terminals on the end of your wire in addition to the fuse. It does not look like it would be water tight, so you will need to boot it if you need a waterproof connection.
i run the cheapo ones w/o issue. it all depends on where you will have it mounted at.
I agree as long as it is not under the hood //content.invisioncic.com/y282845/emoticons/fyi.gif.9f1f679348da7204ce960cfc74bca8e0.gif
Under the hood, I would want a water tight unit. In the trunk, not so much.
Thanks for the help im just going to get a good one for under the hood and then some cheap ones for in the trunk. Last question never worked with the anl fuse min usually just plug in. Now i just loosen the nut put the fuse in and tighten the nut? i could be wrong cause im just going by the picture haha
MikeCole89
MikeCole89
Connecticut
TnT_Sounds
