Fuse to use??
PWNED
I am going to be installing my system sometime in the next month.I will be running the MTX TA81001 with a 12inch FI Q.I will be getting the Dual 2 so it will be running @1ohm.THe amp does about 1500@1ohm.I will also be doing the big 3.I will be using 2gauge wire for all (amp power/ground/big3)I will be using a 200amp fuse inline for the big 3 from alt-batt does that sound right?Also what fuse should i run for the power to my amp?It has four 40amp fuses.
I found this little guide.I am running the stock alt which is 105amps.So really i would only need a 120amp fuse for the alt-batt????OR should i really run a 150for that and my amp power supply.Since the fuses i found were 120/125/150/175.
Wire Gauge Recommended Maximum Fuse Size
00 awg 400 amps
0 awg 325 amps
1 awg 250 amps
2 awg 200 amps
4 awg 125 amps
6 awg 80 amps
8 awg 50 amps
10 awg 30 amps
12 awg 20 amps
14 awg 15 amps
16 awg 7.5 amps
These are the recommended maximum fuse ratings for the corresponding wire size. Using a smaller fuse than what's recommended here will be perfectly safe.
160 total draw. run a 150 fuse. fuses dont pop at rated amperage. they allow more flow before popping. they can let twice the amperage thru for 5 minutes before they go. be safe and get one a little smaller than total draw.
PWNED
PWNED
Hooksett,NH
PWNED
