Fuse Question (Distribution Block)
Slammed
Striking Accord
I have two JBL Amps with a fuse rating of 120 combined....so im thinking about using a 120 Mini-ANL fuse up front (4 gauge wiring).
Im curious to know if I need a fused distribution block?
Also, what would happen if I use 120 ANL fuse up front and 110a fuses with the distro block?
thanks
No. I suspect you're using 4g to your amps. But even if you used 8g, a run that short could handle 120amps.
Nothing with daily use. The 110 fuse would only pop before the 120 if you had a surge of current.
The fuse sizes are close enough that the 120 would likely be damaged before the 110 disconnected the fault.
If you get a fuse distribution block, I would recommend lowering the ratings on the fuses to match the draw of your amps.
so I wouldnt need a fused distro block?
and if I did use one, with my front end being at 120amps (my amps fuses equal to that) I would need a lower fuse size for my distro block?
A fused distro will have a fuse for each output, therefore you fuse for each amp individually.
Slammed
Striking Accord
Slammed
Gotham City, NY
Slammed
