Quad Voice Coil Wiring
CrAiZ3
I searched high and low for the answer. Even did some simple math. And nothing I do seems to come out correct. On top of that, there is virtually nothing on the internet (except for some broken links) that show how to wire a QVC sub to 2ohms.
My current amp:
http://www.sonicelectronix.com/item_9983_Audiobahn+A4801T+R-B.html
2800W Max, Class A/B 4-Channel Car Amplifier
RMS Power Rating:
250 watts x 4 chan. @ 4 ohms
350 watts x 4 chan. @ 2 ohms
700 watts x 2 chan. @ 4 ohms Bridged
Max Power Output: 2800 watts @ 2 ohms stereo or 4 ohms bridged
Full MOSFET Power Supply with Soft Start Class A/B Circuitry
Preamp Outputs
Cobalt Blue Illumination (on/off switch for your preference)
Circuit Board, Heat Sink, Audiobahn Name Plate, Volt-meter and End Caps illuminate
Cobalt Blue Digital Volt-meter Display
Clipping Blue LED Indicators under the volt-meter display
Cooling Fan
Chrome Flame Cooling Fan Grill Cover Included (other optional designs available and sold separately)
Double Sided Glass Epoxy Circuit Board
High Gloss Chrome Plated Finish
Nickel Plated Block Terminals
3-way Protection Circuitry: Thermal, Short Circuit and Overload
High quality Bipolar Audio Stage
On/Off Bass Boost Setting: 0 or +18dB
Variable High-Pass Crossover: 50-750Hz
Variable Low-Pass Crossover: 50-120Hz
Variable Subsonic Filter: 20-50Hz
Signal-to-Noise Ratio: 100dB
Frequency Response: 10Hz-40kHz
THD: 0.02%
4-gauge power and ground leads recommended. Contact us for information regarding a discount on a select amplifier kit when purchased together.
Dimensions: 11-1/2" L x 12-3/4" W x 2-1/4" H
Now that you have seen the specs, can someone please tell me EXACTLY how to wire my two QVC subs to the amp to get the maximum power. All help is appreciated. Thanks.
What impedance are the coils on the subs?
These are your two options:
its probably between 1.2 and 1.4 ohms per coil. the final DCR of all parallel would be 1/4 that... so about 0.35 or 0.3... very low!
look for 1/2 ohm stable amp, or do one amp per coil (2 ohm stable), or one amp per two coils (1 ohm stable)
u sure ur subs are qvc each? not dvc?
Hell. As far as I know. There are four negative and four posative terminals on each sub.
(2) Audiobahn Ultra Excursion A1205N Subwoofers.
Subwoofer Size 12"
Impedance 2 ohms
Dual Voice Coil Yes
Peak Power Handling 2000 watts approx.
RMS Power Handling 1000 watts
Sensitivity 92.9 dB
Frequency Response 23 - 700 Hz
Dual 2-Ohm 4-Layer Edge Wound Voice Coil
Specs on the sub, only for some reason it says they are only DVC.
I was planning on ordering the audiobahn amp tomorrow. I can always change my mind. Feel free to recomend any amps. Hopefully in the price range on $215 that will power two subs at 1000rms a piece.
Hell. As far as I know. There are four negative and four posative terminals on each sub....
Dual Voice Coil Yes...
...Dual 2-Ohm 4-Layer Edge Wound Voice Coil
The 4 neg's/pos's are neg in/out, pos in/out for each VC.
You need around 2000w at either 1/2 or 2 ohms.
Nothing is going to get close to that at in the $220 range, that would even be tricky to do if you're buying used/refurb'd.
The cheapest option I can think of for a new amp is the Lanzar Opti2000D. It will do 1800-1900 at 1/2 ohm -- it's about $330 shipped.
CrAiZ3
CrAiZ3
Pittsburgh, PA
donpisto
