Fuse distance from Battery
  • 4
DarrenE46
Hey everyone, I need to know the reasoning why 18" is the optimal distance for a fuse to be placed from the battery. The battery is in the back on my car and I was hoping to use a fuse dist. block but it may be about 24" away from the battery, would this be ok, or should I fuse it than go to the fused dist. block. Thanks!
isn't critically important what length it is, just close enough to the battery so the fuse -> battery lead won't short out on anything. If you can secure 24" of wire so you're absolutely sure (really, really sure) that it won't short out on anything metal, that's fine.
I made a lot of money repairing fuse boxes that were destroyed from people taping into them. Pay once by doing it right. Do it wrong, the second...
14
680
It would be cheaper, it might be easier to find a place to mount it, and you would have a ton of options if you just do two, 3 slot fuse holders...
660
My bad, yes, I read them each as having two 4ohm coils. The JBL diagram left a bit to be desired, IMO. ;) And a double yes, thought U was talking...
I plan on getting the fuse to run as a front sub/midbass in my kick panels...I've heard they sound good but you definitely wont get mirror shaking...
DarrenE46
DarrenE46
Orlando, FL
desertheat
