full active system
  • 2
I knid of still learning this SQ stuff. But if I'm thinking of the same thing. It means all of your crossovers are active electronic crossovers. Instead of passive crossovers. Advantages would be flexibilty in the crossover points. With most electronic (active) crossovers you can adjust the crossover points infinitly between two points. Where as with passives the only way to change crossover points is either through a switch on the crossover. Or by changing the impedence. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif Any help ?
Ahhh, I had it in my head that it was 1 ohm stable for some reason.
41
COMPLETED Full system sale
Changed my mind, the jetta is staying as-is and I'm buying the new car anyway, close this *****! Matt
I feel like its a bad set(Low tier set) of RCAs myself. I use Stinger Zero Noise and 4000-8000 series without any issues. Dayton makes a nice set...
Yeah but accubass only restores the bass roll off. It doesn't take an incomplete signal range and make it a full range signal.
13
boogieman909
boogieman909
philippines
ramos
