Jeffdachef
Gunz That Turn on Nunz
yeah 32 hz is good to go. As long as you have bracing and a 2nd baffle then you are good to go. You dont really need triple if you have good enough bracing.Thank you bro, you've been so helpful to me over this process...And that is what I listen to alot of re-bass hip-hop.
Looking at the graphs you post looked like u we're using my numbers, so does that mean the the design for the 32hrz I posted is ok? And I planned to double baffle and use a few 1 1/2" dows to stiffen up the box with cross bracing and angling them all to make the air flow smooth. Also planned on priming the entire inside and using a bed liner spray on the outside. Would it be ok to do .75" + .50" + .75" for the baffle, using a 1/2" mfd piece to triple it up instead of 3x .75" or but if when I lay my pattern out if I can't get it done with the double baffle in 2 sheets I'll buy a 3rd and just do it that way. I'm picking up a Craftsman table saw and the wood tomorrow, already got pounds of 1 5/8" and 2 1/2" deck screws, a huge bottle of Titebond III, a new drill bit set, a few tubes of silicone, a bunch of spiked T-Nuts and hex head bolts(only 1 1/2" cuz I planned for double .75 baffle) but I can change em out I got my reciepts. I found a nice looking plunge route table I'm trying to get too but idk if it's still available.
Anyways thank you Jeff can your friggin awesome bro!
I forget where that JVC model you posted was, what was it again plz?
Well if to class talk to y'all later.
The head unit was posted on post number 14.
If you havent bought the wood yet, consider using 11 layered ply over mdf. Its stronger and a lot lighter at the same price point, overall superior by far. Might make the difference between keeping suspension stock or having to put airbag support.
