Sold FS/T: Two Alpine Type X 10" MINT
kotec123
Flame
I've got 2 MINT 10" Alpine Type X Subs here for sale. I had them running off of 700watts from my tantrum, and they did great off that power. They are def the best sounding subwoofers that ive ever herd. They hit super hard and clean. Alot of punch in these subs. They hit lows like no other...in the 20hz range!!! and hits them nice and hard also. I had diamond audio d6's before and these sounded better and gained me 4 db on the TL....Definitally some of the BEST SQ subs out there. These SQ subs can get pretty dam loud. i hit 145.2.....WITH 2 TENS and 700 watts per sub.....!! //content.invisioncic.com/y282845/emoticons/tongue.gif.6130eb82179565f6db8d26d6001dcd24.gif
im lookin to get 425 shipped for both. FIRM (noticing they are mint)....i bought both for $550 ONE MONTH AGO! They msrp at $550 EACH. These are MINT... can get pics, but that would require me to take them outa my box, but i still wanna have subs untill i sell, so if ur interested in purchasing, ill get pics.... There is a pic of one of mine in my Avatar, and it hasnt changed....Still flawless
Belunt on this forum helped me install these babies, so he can vouch for me that they are some badass subs.
10/10 physically
10/10 mechanically
1000w rms //content.invisioncic.com/y282845/emoticons/crazy.gif.c13912c32de98515d3142759a824dae7.gif
3000w peak
19.1 mm one way XMAX!!! (trust me they move alot) hehe:naughty:
Alot of R/D go into the type x....check out these features.
4-Layer High Temp Wire on High-Strength Brass Former
• 4-Layer 220°C High Temp Wire with Inner/Outer Winding on Twin-Wall Brass Former
• Carbon Fiber/Aluminum Honeycomb Parabolic Cone
• Custom Cast Aluminum Frame
• Designed and Engineered in the USA
• Dual Voice Coil Design
• FEA Optimized CRC T-Drive Motor Structure with Copper Shorting Sleeve & Heat Transfer Technology
• FEA Optimized Hhigh Excursion Injected Santprene® Multi-Roll Surround
• FEA Optimized High Excursion Injected Santoprene® Surround
• FEA Optimized Mirrored Progressive Nomex Spiders with Integrated Tensil Leads
• FEA Optimized Mirrored Progressive Nomex Spiders with Integrated Tinsel Leads
• Gold Plated Insert Terminal Block with VC Jumpers
• Hidden Screw Gasket
• Integrated Spider Landing and Heat Transfer Plate
• Massive Triple Stacked Strontium Magnets
• Multi-Stage Ventilation System (Dual Flare Pole, Spider Plateau & Frame Leg Venting, Cone/VC Junction Venting
• One-Sided Terminal Layout
thanks
kotec123
Flame
kotec123
Chicago
Fosgate Forever
