FS: Power Acoustic BAMF 4000/1D
dross93ranger
This amp is in great shape, it is less than a year old and works like a brand new amp. The bass knob is also included, but not pictured. 9/10 Cosmetic (some minor scuffs on the heat sync) and 10/10 mechanical. The bass knob has a blue LED.
$180 OBO Will also do partial trades (An EQ, 4/2 Channel Amp, Offer anything and how much cash you would give) + cash, but I must get ATLEAST $100 with any trade.
4000W Max Monoblock Class D Amplifier Car Amplifier
RMS Power Rating:
4 ohms: 1200 watts x 1 chan.
2 ohms: 1700 watts x 1 chan.
1 ohm: 2200 watts x 1 chan.
Max power output: 4000 watts x 1 chan.
Fully regulated PWM power supply
Wired remote bass level control included
System distress indicator
Four way protection circuit
Adjustable Tuned Bass EQ (0-18 dB Bass Boost)
Hi-Speed digital circuitry
Full selectable crossover (HI,Full,Low
1-Ohm Stable
Full selectable crossover (HI,Full,Low)
Die-cast aluminum heat sink designed for massive heat dissipation from three sides of the amplifier
Heavy duty aluminum alloy heatsink or High-density split-dome convection heat sink for extreme heat dissipation
Platinum-plated RCA level inputs
Platinum-plated screw terminals
Variable low-pass filter (40-200 Hz, 24 dB/octave)
Variable subsonic filter (20-50 Hz)
Variable subwoofer EQ @ 45 Hz
Frequency response: 20-200 Hz
Signal to Noise Ratio: 100 dB
Dimensions: 13-3/4"L x 8-1/4"W x 2-1/8"H
4-gauge power and ground wiring is required for installation. Contact us for information regarding a discount on select amplifier kits when purchased together with this amplifier.
Authorized Internet Dealer
1-year Manufacturer's warranty
I loved it for the year I used it and it took some power, but I felt that it put out plenty of output as well. Also she is my first, I'm holding her as I type this message //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
not gunna lie this amp looks like a mix of rockford fosgate and ed hardy. lol
LOL, I just need it gone so I can buy some matching AP's. I will accept lower to an extent or lower and a trade, so people make some offers!
I would like an AP 2-4 channel + cash.
probably got the gain turned waaay up. Also remember this is just a 2 ohm stable amp. Make sure your subs are wired for a 2 ohm load on the amp...
Who had that Badazzed Astro Van?? I remember going to Austin seeing that ride. That thing made Earth pavement move about 50 ft before I got close...
545
Run the biggest AGM you can under the hood, the parallel runs to one of these - should be everything you need and then some...
733
dross93ranger
dross93ranger
Maysville, KY
corrykid
