Sold FS: Massive Audio CA100 - $200 OBO
sundownz
Pro Seller
Supporting Vendor
If you have an offer MAKE IT... I will not answer a PM that says "What is the lowest you will take?" NO TRADES!!!!!
This amp has been tested on my bench and is guaranteed not to be DOA. No further warranty is expressed or implied. The item must be tested in no more than 5 days after receiving it -- do not e-mail me 2 weeks later... If you don't have the time or capability to test it within 5 days then don't buy here.
520w x 2 RMS / 1040w Max., high current amplifier, bridgeable. 18db bass boost @ 45 Hz. Continuously variable 18db X-over with phase shift/time alignment control. Balanced line inputs. Surface mount technology (SMT). Mil-spec. double-sided gold plated Circuit Board. Regulated dual power supplies using PWM switching. MOSFET transistors used in both input and output stages. On board computerized protection monitor. 1 ohm stereo, 2 ohm mono.
Weight 14.00 Pounds
RMS Power 520 x 2
PEAK Power 2080 x 1
RMS@2Ohms 330 x 2
Bridged RMS 1040 x 1
Min Impedance 1 Ohm
Min Impedance Bridged 2 Ohm
THD 0.005
S/N 112 dB
Max Voltage 16v
Max RCA Voltage 4.5v - 18v
Freq. Responce 5Hz - 50Khz
Dimensions 9.75" x 2.5" x 11.5"
sundownz
Pro Seller
Supporting Vendor
sundownz
North Carolina
sundownz
