Sold Fs/ft: Treo Ssx2000.1
kowboy
Treo ssx2000.1: Used for about 1 month...amp is in 10/10 condition - both cosmetically and mechanically - there's not a single scratch. This thing is very underrated! I've been told that they are closer to 2500rms, maybe even close to 3000 at 1/2 ohm(which is what I ran it at). Amp is advertised at 1 ohm stable though...Comes in original box with bass-boost knob.
I'm asking $400 shipped OR BEST OFFER (I am very motivated to sell/trade) -As far as trades go: Looking for huge mono amp only...I obviously will add cash.
SSX2000.1
750Wx1 @ 4 Ohms 0.1% THD 14.4VDC
1300Wx1 @ 2 Ohms 0.1% THD 14.4VDC
2000Wx1 @ 1 Ohm 0.1% THD 14.4VDC
Features:
Eight different models to choose from including two stereo class-A/B models, teo four channel Class-A/B modela, and four monoblock Class-D models means there is a TREO SSX amplifier for every application.
Massive extruded aluminum heatsink with precision CNC-machined TREO Engineering logo
Low-profile heatsink design allows many installation options
Gold-plated terminals for all inputs and outputs
All models can accept up to 8V RCA input
Adjustable 12dB/octave high-pass (50Hz-550Hz)/low-pass (50Hz-550Hz) filters on Class-A/B models (SSX200.2 & SSX80.4)
Adjustable 24dB/octave low-pass (50Hz-150Hz) filters on Class-A/B models (SSX800.1 & SSX1400.1, SSX2000.1)
Adjustable and defeatable (15Hz-40Hz) subsonic filter on Class-D models (SSX400.1, SSX800.1, SSX1400.1, SSX2000.1)
Class-D models (SSX400.1, SSX800.1, SSX1400.1, SSX2000.1) feature high-current one ohm stability.
Power LED shines blue when the amplifier is on.
Clip Indicator LEDs make adjusting gain settings very simple on all Class-A/B models (SSX100.2, SSX200.2, SSX40.4, SSX80.4).
Master/Servant ability on Class-D models (SSX400.1, SSX800.1, SSX1400.1, SSX2000.1) allows two amplfiers to drive a common load
Master/servant bridging cable included with all Class-D models (SSX400.1, SSX800.1, SSX1400.1, SSX200.2) allows bridging of two like amplifiers for maximum output into one two ohm channel.
Class-D models (SSX400.1, SSX800.1, SSX1400.1, SSX2000.1) feature Remote T-Bass control for continuously variable 0-18dB gain centered at 42Hz from the driver's seat.
All models feature cooling fans for enhanced heat dissipation abilitiy.
Under/Over-voltage, thermal, and short circuit protection on all models.
Three-year dealer installed warranty
I have a cliff 4800.1LX its absolutly flawless. I'm on my phone but specs are 5200 at 1 and is .5 ohm stable
Sounds like a pretty sweet amp, plus you're local (sorta)...I'll get right back to you in a minute - I'm having a hard time getting any info. on the interwebz.
Bad *** amp. You should have traded with me a while back.
Anyways, I'm in Detroit, so PM me whatever you can do picked up. No promises, but I'll see what I can do. Really like those treo amps. My girl will probably kill me if I pick up anymore toys though.....
kowboy
kowboy
The "D"
kowboy
michigan born
    May 14, 2026
michigan born
    May 14, 2026
