Fs: Jl audio, zapco and dls
shutmdown
DLS A3 TWIN MONO
ZAPCO REFERENCE 360.4
JL AUDIO 300/4 V1
DLS A3 - Used in excellent condition minus a few blemishes near the mounting feet and a few scratches that are pictured. Trying to downsize to digital amps need to sell.
Zapco Reference 360.4 - Used in good condition, only issues is a few cosmetic stains. For those who have owned these amps they know for some reason the covers stain very easily. One of the outer tabs that separates the Power and Ground wire is chipped off. This does not affect performance. If you check the pictures i've uploaded it is the outer piece that does not interfere with the power touching ground. I accidentally broke that when my terminal rotated and snapped that piece. Other than the cosmetic issues the amp runs flawlessly.
JL Audio 300/4 version 1. - this amp is working however seems to have one channel that is bad. It is the rear right channel. It has distortion in this channel. Apparently it has a bad transistor somewhere along that channel. You can either send it in to get repaired by JL Audio OR daveds50 from DIYMA can repair it for 55-70. I can pass along his information if that is the route you'd like to take. Other than that all 3 channels work fine.
DLS A3 - $300
Zapco 360.4 - $180
JL Audio 300/4 - $100
or best offer, but please dont low ball me.
I am looking for a few amps for trade, Alpine PDX F-6, Hertz HDP-4, Mosconi Gladen AS 100.4, Zapco DC Reference 1000.4, 650.6, 750.2 or 1100.1
Shipping will be at buyer's expense. I'd rather deal with local so buyer can see what they're buying and also I can demonstrate that all amps are in working condition. Just had all amps bench tested by local shop who is MECP certified. I have a receipt from him that states amps 1 & 2 are in working order while amp 3 - has a malfunction in channel 4.
I've been a lurker on caraudio, i have a few transactions on DIYMA under the same id and a few transactions on v6performance.net under id 1blwn_accord
DLS A3
heres the close up of the broken tab on the zapco
you can see the broken tab it is to the left of the fuse. As stated it has no affect on performance
shutmdown
shutmdown
cali
shutmdown
michigan born
    May 14, 2026
michigan born
    May 14, 2026
