Fs: Jl audio, zapco and dls
shutmdown
DLS A3 TWIN MONO
ZAPCO REFERENCE 360.4
JL AUDIO 300/4 V1
DLS A3 - Used in excellent condition minus a few blemishes near the mounting feet and a few scratches that are pictured. Trying to downsize to digital amps need to sell.
Zapco Reference 360.4 - Used in good condition, only issues is a few cosmetic stains. For those who have owned these amps they know for some reason the covers stain very easily. One of the outer tabs that separates the Power and Ground wire is chipped off. This does not affect performance. If you check the pictures i've uploaded it is the outer piece that does not interfere with the power touching ground. I accidentally broke that when my terminal rotated and snapped that piece. Other than the cosmetic issues the amp runs flawlessly.
JL Audio 300/4 version 1. - this amp is working however seems to have one channel that is bad. It is the rear right channel. It has distortion in this channel. Apparently it has a bad transistor somewhere along that channel. You can either send it in to get repaired by JL Audio OR daveds50 from DIYMA can repair it for 55-70. I can pass along his information if that is the route you'd like to take. Other than that all 3 channels work fine.
DLS A3 - $300
Zapco 360.4 - $180
JL Audio 300/4 - $100
or best offer, but please dont low ball me.
I am looking for a few amps for trade, Alpine PDX F-6, Hertz HDP-4, Mosconi Gladen AS 100.4, Zapco DC Reference 1000.4, 650.6, 750.2 or 1100.1
Shipping will be at buyer's expense. I'd rather deal with local so buyer can see what they're buying and also I can demonstrate that all amps are in working condition. Just had all amps bench tested by local shop who is MECP certified. I have a receipt from him that states amps 1 & 2 are in working order while amp 3 - has a malfunction in channel 4.
I've been a lurker on caraudio, i have a few transactions on DIYMA under the same id and a few transactions on v6performance.net under id 1blwn_accord
DLS A3
What are the specs on that DLS amp by the way?Thanks
Number of channels 2
Amplifier class AB
Mono bridge mode 1.33 ohm 1000 W RMS
Mono bridge mode 2 ohm 870 W RMS
Mono bridge mode 4 ohm 550 W RMS
Output power in 1 ohm 2 x 425 W RMS
Output power in 2 ohm 2 x 270 W RMS
Output power in 4 ohm 2 x 150 W RMS
Damping factor > 200
S/N ratio, A-weighted > 100 dB
Input impedance, high level N/A
Input sensitivity 0,2 - 7 Volt
Input impedance > 10kohm
Frequency range 10 Hz - 50 kHz
High pass filter 20 - 200 Hz
Low pass filter 50 - 125 Hz
Low level output No
External cooling fan terminal Yes
High level input with auto start No
Dual DC inputs Yes
Power consumption (idle) 1,1 A
Power consumption (max) 140 A
Rec. power cable Minimum 2AWG / 33 mm2
Fuses 4 x 30 A
Dimension (W x D x H) 410 x 240 x 73 mm (16,15 x 9,45 x 2,87 inch)
Weight 6,2 kg ( 13,67 lb)
Number of channels 2Amplifier class AB
Low level output No
Dual DC inputs Yes
Fuses 4 x 30 A
Thank you sir..Looks like it would make a real BA front staging amplifier, or a nice mono amp for a good 1000rms sub
shutmdown
shutmdown
cali
shutmdown
