SOLD FS/FT: MTX 275x
  • 4
WashYourWinky
The Pilot
I have a near mint condition MTX 275x. Looking to sell for $90 shipped in the US.
Mechanical 10/10 Cosmetic 9/10
Comes with the original manual.
Specs:
RMS Power measured at 12.5 Volts DC:
37.5 Watts x 2 into a 4 Ohm load with less than 0.05% Thd+N
75 Watts x 2 into a 2 Ohm load with less than 0.1% Thd+N
150 Watts bridged into a 4 Ohm load with less than 0.1% Thd+N
Dynamic Power (IHF-202 Std) measured at 14.4 Volts DC
85 Watts x 2 into a 4 Ohm load
140 Watts x 2 into a 2 Ohm load
280 Watts bridged into a 4 Ohm load
Signal to Noise Ratio:
> or = 110dB A-Weighted
Damping Factor:
>200
Frequency Response:
20Hz-20kHz±0.25dB
Thunder EQ:
Variable Bass Boost (0-18dB) centered at 40Hz
Crossover:
Variable 50Hz to 200Hz, 18dB/Octave, High Pass or Low Pass Configurable
Dimensions
8" x 9" x 2" (20.3cm x 22.8cm x 5cm)
9-1/4" x 9" x 2" (23.5cm x 22.8cm x 5cm) Including IsoFeet™
I don't really need it...I have one just like it thats been sitting in my closet for 2 years...If I buy this one it will sit next to it....But I figured I'd offer $70 just to have another amp I might use someday...lol...
150 bridged with two 20a fuses? Haha //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
Obviously underrated, as are any MTX amps of this era. Good, clean power too.
GLWS!
GLWS!
Thanks!
Yes, underrated! Love the amp just don't need it and I'm not a collector.
Thanks buddy! Given me a lot to think about in terms of what to do; I've been watching YouTube videos on this stuff all day as well so I really...
698
You can wire those subs up @8 ohms if they are both SVC4 ohm subs,and that amp will run fine after being tuned properly...
The 240 should be 2x40/ 2ch. rated at 11.9v. Should generate close to 50+ @14v rms. Only Rated @4 ohms bridged Mono.. Should be around 125 rms...
In 1990: The MTX MTA 225 had a MSRP of 549.95 25x2 0.02% THD S/N 102 12x 8 1/2x 2 3/8 The MTX MTA 250 had a MSRP of 649.95 50x2 0.02% THD S/N...
WashYourWinky
The Pilot
WashYourWinky
Cincinnati, Ohio
WashYourWinky
pfft
    May 1, 2024
pfft
    May 1, 2024
