Sold FS/FT: MTX 275x
WashYourWinky
The Pilot
I have a near mint condition MTX 275x. Looking to sell for $90 shipped in the US.
Mechanical 10/10 Cosmetic 9/10
Comes with the original manual.
Specs:
RMS Power measured at 12.5 Volts DC:
37.5 Watts x 2 into a 4 Ohm load with less than 0.05% Thd+N
75 Watts x 2 into a 2 Ohm load with less than 0.1% Thd+N
150 Watts bridged into a 4 Ohm load with less than 0.1% Thd+N
Dynamic Power (IHF-202 Std) measured at 14.4 Volts DC
85 Watts x 2 into a 4 Ohm load
140 Watts x 2 into a 2 Ohm load
280 Watts bridged into a 4 Ohm load
Signal to Noise Ratio:
> or = 110dB A-Weighted
Damping Factor:
>200
Frequency Response:
20Hz-20kHz±0.25dB
Thunder EQ:
Variable Bass Boost (0-18dB) centered at 40Hz
Crossover:
Variable 50Hz to 200Hz, 18dB/Octave, High Pass or Low Pass Configurable
Dimensions
8" x 9" x 2" (20.3cm x 22.8cm x 5cm)
9-1/4" x 9" x 2" (23.5cm x 22.8cm x 5cm) Including IsoFeet™
WashYourWinky
The Pilot
WashYourWinky
Cincinnati, Ohio
WashYourWinky
