FS: FI BL w/ 4" Coil!
brmcm15
Oh lawdy!
You read it right, 4" coil. This thing is a monster!
Loaded with cooling and flatwind coil options.
Dual 2 Ohm
Fs: 39.8 Hz
Re: 1.4 Ohms/coil
Qms: 4.72
Qes: .25
Qts: .24
Mms: 212g
Cms: 0.96mm/N
Sd: 480cm^2
Vas: 31.2 l
Spl: 89.1dB 1W/1m
Bl: 22.7 N/A
Xmax: 18mm
Rms: 1500W *
Sealed box: N/A cuft
Ported box: 1.5-2.5cuft
Sub OD: 12.500”
Cut ID: 11.125”
Mounting depth: 6.750”
Displacement: 0.18cuft
I love this sub but I'm in the process of getting a new car so I need it gone asap!
Mechanically - 10/10
Physically - 7/10
$250 shipped to lower 48
No Trades.
I believe that's a 10" by comparing to that folded sheet of paper! Looks like a nice sub. You may want to explain what type of box and dimensions this was in for reference for future buyers. GLWS. I had hoped to see accepting trades and it be an 18" sub! //content.invisioncic.com/y282845/emoticons/up2something.gif.dd110ecf3ae4b76050d87598f2f8de7c.gif
I guess my previous warning was not sufficient. I didnt take the time to delete all those off-topic, disrespectful and insulting replies for nothing. Now Im annoyed. 9515ROB has earned a 3-day ban. And if anyone else continues breaking the rules here, their ban will be longer.
Rob is not the only one to break a rule here, he's simply the one who showed up on radar first after Id already gone through and cleaned this thread up once. If I have to clean this thread up a third time... well... lets just not see what would happen at that point, it wouldnt be pleasant. So let me be clear... there is no post dumping, item bashing, price questioning, insults or otherwise rude comments allowed in the classifieds. Thank you for complying to the rules from here on out. That includes OP's, potential buyers, and all other people who may or may not have interest in the thread.
edit: brmcm15, if there are any other posts you want me to delete, pm me. Or if you want to start a new thread from scratch, I can delete this one for you.
Thanks. I appreciate it!
2x 4 ohm coils can be wired parallel to 2 ohms or series to 8 ohms. There's many amps with 2 ohm power you can use.
620
Not a term, a description. When it clips, it sends a distorted signal (current) through. A square wave contains more energy than a sine wave and...
27
Okay i found one under b stock on alphards shop site but unable to actually place order grrr
brmcm15
Oh lawdy!
brmcm15
Macomb, Michigan
hispls
maylar
    Jun 2, 2024
    Jun 1, 2024
