You read it right, 4" coil. This thing is a monster!
Loaded with cooling and flatwind coil options.
Dual 2 Ohm
Fs: 39.8 Hz
Re: 1.4 Ohms/coil
Qms: 4.72
Qes: .25
Qts: .24
Mms: 212g
Cms: 0.96mm/N
Sd: 480cm^2
Vas: 31.2 l
Spl: 89.1dB 1W/1m
Bl: 22.7 N/A
Xmax: 18mm
Rms: 1500W *
Sealed box: N/A cuft
Ported box: 1.5-2.5cuft
Sub OD: 12.500”
Cut ID: 11.125”
Mounting depth: 6.750”
Displacement: 0.18cuft
I love this sub but I'm in the process of getting a new car so I need it gone asap!
Mechanically - 10/10
Physically - 7/10
$250 shipped to lower 48
No Trades.
Dual 2 Ohm
Fs: 39.8 Hz
Re: 1.4 Ohms/coil
Qms: 4.72
Qes: .25
Qts: .24
Mms: 212g
Cms: 0.96mm/N
Sd: 480cm^2
Vas: 31.2 l
Spl: 89.1dB 1W/1m
Bl: 22.7 N/A
Xmax: 18mm
Rms: 1500W *
Sub OD: 12.500”
Cut ID: 11.125”
Physically - 7/10
No Trades.
