Sold FS: Car audio & Motor stuff
Mr. Nipples
Pimp ***
Item #1: XxX 15" DVC sub, hes cooked however and need a recone from RE.
Item#2: (2) Kicker 10" L7', one of the subs has two Tinsel leads that have popped off (common problem on the old school Kickers) and they can be repaired at most speaker shops for bout 25 bucks.
Item#3: Small block ford out of an 89 stang. Its a 302 bored out to 347, recently magnafluxed and pressure tested. Its been stored in a sealed tote with oil to keep it from rusting.
Item#4: Ford Racing 347 Stroker kit complete in box with everthing you will need, crank shaft, pistons, etc.
Item#5:Ford Racing 302 Oil Pan complete in box
Item#6:Ford Racing 302 Flywheel Complete in box
Item#7: Ford Racing Harmonic Balancer
Item#8: Ford Racing SVO high Performance Timing chain set, with full roller multi index complete in box
Item#9:Ford Racing Engine gasket rebuild kit complete in box
Thanks and lemme know everyone.
The machine work was done locally at RT cylinder head, all the work was professionally done. the only number I can find is 8A26, its not where it says it is but thats the only number on the block
Should start with E or F, followed by a number, then ZE or ZZ, then a dash and four numbers after that.
Mr. Nipples
Pimp ***
Mr. Nipples
Grand Rapids
HOAX_1
