Sold FS: Car audio & Motor stuff
Mr. Nipples
Pimp ***
Item #1: XxX 15" DVC sub, hes cooked however and need a recone from RE.
Item#2: (2) Kicker 10" L7', one of the subs has two Tinsel leads that have popped off (common problem on the old school Kickers) and they can be repaired at most speaker shops for bout 25 bucks.
Item#3: Small block ford out of an 89 stang. Its a 302 bored out to 347, recently magnafluxed and pressure tested. Its been stored in a sealed tote with oil to keep it from rusting.
Item#4: Ford Racing 347 Stroker kit complete in box with everthing you will need, crank shaft, pistons, etc.
Item#5:Ford Racing 302 Oil Pan complete in box
Item#6:Ford Racing 302 Flywheel Complete in box
Item#7: Ford Racing Harmonic Balancer
Item#8: Ford Racing SVO high Performance Timing chain set, with full roller multi index complete in box
Item#9:Ford Racing Engine gasket rebuild kit complete in box
Thanks and lemme know everyone.
for all the motor stuff i was lookin to get about 1600 bucks plus shippin, shippin to you flip is 355 some dollars but according to fed ex taht could change but whatever i can deal with the extra if there is any and if it ends up bein less i'll refund whatevers left.
XxX=120 shipped
L7's 90 shipped
Motor stuff 1600 bones without shipping its going to be on a case to case basis.
Great great price on the motor and such. I assume it does not come with heads/intake/headers, etc. because there are none in any of the pics. If you purchased these items in a kit, could you please tell me which one? Also, that flywheel will work with a t-5 correct?
The Flywheel will work with a T5 yes, and I purchased all the components seperate but Id rather sell it as one big mass to make life easier, the only picture I dont have is of the harmonic balancer which is still at the dealer that I still have to pick up. No heads, intake, or headers however.
The coils are popped at hte connectors i can send a pic to you via email, and they are dual 4 ohm.
XxX is in the process of being sold
L7's still available
Motor stuff too available as of right now
Mr. Nipples
Pimp ***
Mr. Nipples
Grand Rapids
HOAX_1
