FS Batteries CHEAP!!
michaellane
tx
Don't pay $80-100 for a used HC600 or Batcap 800, or even more for a XS D680...get more power reserve, and for less $$!
21lbs
26ah rating
7" long x 6.5" wide x 5.2" to top of tabs (rounded up a tiny bit)
Totally sealed and non-spillable AGM technology
40% more weight and higher ah rating than a Kinetik HC600 or XS D680
Resting voltage is between 12.+
All load test just like they're supposed to.
This will make a great secondary battery for mid size systems that need a little extra reserve power for when the alt just can't quite keep u
never used all sit at 12.4 or higher. ALL ARE BLACK
$53.00 shipped
Good seller here. I may need to hit you up for 8 of the Deka Intimidators...SPL time!
I went tonight and got a few of those 105ah and a bunch of these //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
21lbs
26ah rating
$55.00 shipped
F*CK...... where were you like 2 weeks ago.....
Definitely going to pick one or two if these up. Going to be running a 1500 watt mono and 300 watt two channel, do I need two? I have a yellow top up front.
More never hurts and I would honestly say 2 should be good.
And im sure yoj already know but these things are going fast left and right from somewhere someone is buying them 3 or more at a time
How have you verified that your alternator is making that much current under real world operating conditions in your vehicle?
992
That would be close to 4000w rms give or take. I recommend a 75ah or larger AGM battery and a 240a or larger alternator. And you will need 2/0 or...
NADBL is the org that we get up here in the northeast, they do some shows in Ohio and upstate NY and into Canada, might be close-ish to you...
36
4K
Just the amplifiers use batteries to power it up. The HU are powered up by the car battery supplying 12 volts. The wiring harness...
michaellane
michaellane
tx
mrbadwrench
just call me KeV
    May 1, 2024
just call me KeV
    May 1, 2024
