FS Batteries CHEAP!!
michaellane
Don't pay $80-100 for a used HC600 or Batcap 800, or even more for a XS D680...get more power reserve, and for less $$!
21lbs
26ah rating
7" long x 6.5" wide x 5.2" to top of tabs (rounded up a tiny bit)
Totally sealed and non-spillable AGM technology
40% more weight and higher ah rating than a Kinetik HC600 or XS D680
Resting voltage is between 12.+
All load test just like they're supposed to.
This will make a great secondary battery for mid size systems that need a little extra reserve power for when the alt just can't quite keep u
never used all sit at 12.4 or higher. ALL ARE BLACK
$53.00 shipped
Are these the only terminals on them???
Yes. You use ring terminals just like you woukd with batteries that use the bolt type terminals.
---------- Post added at 09:01 PM ---------- Previous post was at 09:00 PM ----------
noob question: how do you hook up to those terminals?
Ring terminals on the end of your wire and nut and bolt it on. Very simple.
michaellane
michaellane
tx
mrbadwrench
