FS: (3) Very Custom 10" HX2 Punch
Purplehaze-
3 - Custom built Punch HX2 10's
Like new, very slightly used. (Maybe 10 hrs total @200w rms each)
- Specs: 3" D2ohm coils, dual ZV3 spiders, stitched leads, 10g chrome push terminals, carbon fiber cones (overlay), black poly dust caps. 12 spoke frames (new) with custom base/ clear paint.
*ts parameters available upon request.
$130 each shipped (Cont. U.S. only)
Buy all three, get a free enclosure! (the one pictured)
Free shipping - cont. US only
750 RMS each*
*rookie rating
How'd they sound ? I'm interested in all 3
They sounded great. They did very well for such low power.
750 each (probably take 1000+ each of good clean power)
Really digging the paintjob on those frames, mind sharing how you did that? Free bump.
Thanks. Sure.
That is actually just multi step paint, with clear on top. First I paint the stripe color, then after light sanding and masking, I paint the main color. Then remove the tape, clean, then top with high gloss clear.
It takes some time but is worth it in my opinion!
box specs..power handling
Box is separate chambered (3) @1.12ft3 each chamber, the subs are 750 RMS each for rookies, or 1K each for vets.
Once again you impress the crowd with your work.. Putting those baskets inside an enclosure is borderline criminal... I told you brotha man you need to just create your own artwork and graphics to put on these builds so when they are installed all over the place people know who is behind the beasts in the sub stage... I'd rather have purple frames and your logo/artwork then whatever the sub started out as before you improved it dramatically....
10
Did you try the red on both sides, then the white on both sides. It may be a bad cable.
"I don't have any crossovers" You'll need one to filter out the low frequencies leading to your sub woofer. They'll produce no sound then...
14
Purplehaze-
Purplehaze-
Hell's Half Acre
negolien
