Sold FS: 2 American Bass 500.1's
basebalz13
D-money
im selling two american bass 500.1's. these are in pretty much new condition but has probably around 5-10 burps on them. these things a friggin tanks and i loved them. however small truck with lots of big amps doesnt work to good //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif
trades are soundigital 8000.1's
price- 850 each
why do you want to know what it does at 12 volts anyways? did you say something like because your running a 12 volt setup. well your alt will charge at 14.4 or higher FYI
nooo shittt you think lets see your voltage wont never be 14.4 after voltage drop so an amp rated at 14.4 does no good after drop it if does 5k at 14.4 and 3k at 12 volts then u wont get 5k watts from it:rolleyes:
heres what I found
1 x 1400W @ 4 ohms (14.4V - 1% THD)
1 x 2650W @ 2 ohms (14.4V - 1% THD)
1 x 3200W @ 1 ohm (12V - 1% THD)
1 x 4700W @ 1 ohm (14.4V - 1% THD)
1 x 5600W @ 1 ohm (16V - 1% THD)
1 x 7100W @ 1 ohm (18V - 1% THD)
Signal to Noise : 85dB
Damping Factor : 200
Efficiency : 75%
American bass lies on their site they say 6500 watts what at 17 volts, thats my point
heres what I found
Efficiency : 75%
then you have shitty electricical....
i dont ever drop below 14.8 with one amp LOL //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
not to mention the amp is underrated hmmmm
I would love to hear your electrical and running 5k and not droping below 14.8 must be running 16 volts or a MLA at 15.2?? I am talking bout idle not driving voltage
couple powermaster D3100's, couple hundred feet of 1/0, currently one mechamn 250 bout to add another for more amps. charging at 15.4 volts
how often are you at idle also?
umm anytime you compete you are at idle, also dont you demo at idle?? either way you still need good voltage at idle. I thought thats the main reason people get alts to do alot at idle right??
15.4 volts ext reg?? or MLA. I bet at idle you drop
12v isnt idle lol.unless your alt *****.
Your voltage is gonna drop at idle with a good alt if you are running tons of power dont act like its not gonna happen
SWFL, i dont see why your in here trying to find a reason to bad mouth him or the amp just because he didnt want to jump through your hoops for nothing. Grow up.
I aint bad mouthing the amp or him just was curious about the power output at 12 volts and curious why AB rates it at 6500 according to the specs i found thats at 17 volts
either way I am out of here good luck
i compete at 2000 rpm.
also thats just dumb to demo at idle if you ask me
and my alt is 150+ at idle
basebalz13
D-money
basebalz13
roanoke, virginia
basebalz13
slater
    Oct 4, 2025
    Oct 4, 2025
