Sold FS 2 Alpine Type E 12" Subs
tjsharktank
$75.00 Price is for BOTH subs. Buyer pays shipping, choice of method.
SPECIFICATIONS
Power Handling
• Power Handling Capacity (Peak) : 750W
• Power Handling Capacity (RMS) : 250W
General
• Diaphragm Material : Kevlar Reinforced Pulp
• Spider Material : Dual Oversized Nomex
• Voice Coil Diameter : 38mm
• Mounting Depth (top mount) : 159mm (6.4")
• Mounting Diameter (top mount) : 274mm (11")
• Magnetic Weight : 64oz.
• Recommended Box Types : Sealed/Bandpass
• Recommended Sealed Box Volume : 0.6 - 1.25 cu. ft.
Thiel Small Parameters
• Impedance (Nominal) : 4 ohm
• Frequency Response : 28Hz - 1kHz
• Sensitivity : 89 dB/W/M
• D.C.Coil Resistance (Re) : 3.6 ohm
• Inductance (Le) : 2.78mH at 1kHz (0.8mH at 20kHz)
• Free Air Resonance (Fs) : 31Hz
• Equivalent Suspension Stiffness (Vas) : 61 liters(2.3cu.ft.)
• Mechanical Q (Qms) : 9.68
• Electrical Q (Qes) : 0.70
• Total Loudspeaker Q (Qts) : 0.66
• Linear Excursion (X linear) : 11.7mm
• Maximum Excursion (X peak) : 23.4mm
• Mechanical Excursion (Peak-to-Peak) : 40mm
• Gap Height (Hag) : 10mm
• Coil Height (Hvc) : 33.4mm
• Cone Area (Sd) : 490.87 sq. cm
i thought the white cones were the swe 1241's with 200rms and the newer gray cones were the swe 1242 with 250rms. my bro used to have a swe 1241 with 200rms and it was a white cone... maybe im wrong?
tjsharktank
tjsharktank
Charleston
Civic96Lx
michigan born
    May 14, 2026
michigan born
    May 14, 2026
