Frozen Subwoofer Testing Results
bigbassman
Premium Member
Master of all things loud
Ok... here's what I did..
Profile 6.5" subwoofer was used for testing..
standard OEM design.. foam surround, phenol treated cloth linear spider
power provided by my subwoofer amp for the computer system..
woofer was tested free air
Room temperature testing
spider temp 76 degrees
motor temp 76 degrees
power input 22v , 2.5a = 55 watts
full excursion @ 55hz for 2 minutes
in 20 degree F for 1 hour
spider temp 50 degrees
motor temp 38 degrees
power input 22.8v, 2.9a = 66 watts
full excursion @ 55hz for 2 minutes, no detectable issue with suspension
in 20 degree F for 8 hours
spider temp 48 degrees
motor temp 22 degrees
power input 22.3v, 3a = 67 watts
full excursion @ 55hz for 2 minutes, no dectectable issue with suspension
so it appears to me that the spider doesn't freeze and break when the woofer gets cold.
discuss
Loyd L.
Good info............I could send you a 12" L7 to mess around with //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
Someone send him an AQ HD3 to mess around with. I would but i do not have one or the cash flow to get one at this time. But i would like to see some testing on this sub. If yous don't mind that is.
discuss
Loyd L.
You need to be like mythbusters and see what it would take.
Liquid Nitrogen FTW.
'Air' cans turned upside down can substitute if you cant get ahold of liquid nitrogen. //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
I'd imagine that you would see a huge drop in impeadance if you got the coil to 73k.
shits pretty cold on the hand
bigbassman
Premium Member
bigbassman
Southern WV
Bumpin' Goalie
BP1Fanatic
BP1Fanatic
