From good to bad : amp swap
eas
13
Ireland
Hi,
Pretty limited experience here, I know the very basics of installing a simple system, so was hoping some experts could help me out here with some advice.
I decided to up the game a little bit on the audio front in the car & ordered a 5 channel Kicker amp (4X75 + 1*250) to replace my 4 channel (4*50) Pheonix Gold amp.
I got the new amp yesterday & thinking that it would be a simple swap out, I unhooked the Pheonix and dropped the Kicker in. To my disgust, when I turned the car on for a test, engine whine central!
Never heard a hint of whine with the Pheonix Gold at any volume, so now I'm confused about where it could be coming from?!? I'm having some issues with the rear channels of the amp as well, seems to be acting up a bit but I havent really had time to troubleshoot properly.
The more I think about it, the more I'm thinking the whine could be a problem with the amp - nothing in the set up changed with exception of the amp.
Just wondering if someone could let me know any other reason why this could be happening? I know the Kicker is considerably more powerfull than the Pheonix Gold.....but still.
thanks
this is a noob question... but.....
did you unhook the battery before you swapped the amp in? did you 'hot swap' the rca's? what headunit?
thanks guys, answers below...
yes, unhooked neg. on battery first. Head unit is a pioneer DEH-9300SD
DEH-9300SD CD Tuner with iPod Control, Music Browser, Front USB, SD and 3 Hi-Volt RCA Pre-outs (White) (2011 Model) - Pioneer Car Audio - CD Player
your power wire crossing any of the RCA's?
No, power runs down one side & insulated RCA's down the other
model of both amps
KICKER-08ZX7005
Phoenix Gold Octane-R 5.0:4
thanks for that - I will try groudingRCA's but wouldnt if it was a problem with the RCA ground, wouldnt it have been the same with the Pheonix Gold?
those PICO fuses in the pioneer units seem to be fragile. thats why i asked about the rca's hot-swap. i stay away from pioneer for that very issue. i'm not 100% guaranteeing that is the problem though.
you do know how to ground the rca's, right?
(similar to this)
cool, thanks for that. This is the first I've heard about this pico fuse BS. I knew I should have stuck with alpine.
If hot swapping causes this to happen, then it's possible that I've blown that fuse, I was swapping RCA's around trying to figure out another issue.
Head unit is a complete pain in the hole to get at... I hate this stuff.
bingo.
WTF...again, should have stuck with Alpine.
I'm going to hook my old amp up first though, just to see.
probably the deck, if its reeeal bad that is.
---------- Post added at 08:03 PM ---------- Previous post was at 08:03 PM ----------
on that note, grounding it will fix it and you wont notice
ok, so spent the past hour or so troubleshooting this.
Before I turned the ignition on I did a test, no noise. I did a 4 channel balance/fader test just to be sure all was good there. I found that the signal into the front left speaker was quite weak compared to the front right. First thing I did was reverse the left + right speaker cable on the amp, the problem followed the cable to the right front speaker...problem in the speaker cable connection to the amp?! Unhooked & rehooked the cable several times, the problem was not with the connection on the amp side. So, I gave up on that problem & moved onto the bigger problem, the engine whine.
Starting with the earth, found a solid place for the cable and dremeled the paint clean off. Tested, nope..still loads of engine whine. BUT....I noticed it was mostly (or all) coming from the bum speaker I tried to fix earlier. Went to the amp and unhooked the speaker. Bingo, clean signal in the rest of the system.
So, the speaker cable is what's causing the problem & it seems it's only to one speaker. Now, as much as I hate to admit it, I think I'm probably a victim if my own lazyness....I may or may not have been as carfull as I should have been while hooking the new speaker cables to the OEM lines. When will I ever learn....
2 possibilites as see them are
1) as stated above, it's behind the head unit
2) the cable has become damaged somewhere between the amp & head unit.
Any other theories ?
I'm still confused as to why this did'nt seems to cause issues with my other amp?!?
thanks for help above.
Cheers
ok, another update...
I was wrong earlier when I thought it was speaker cable. After 5 hours I've finally solved the problem, it was an RCA lead.
Basically had the head unit out so figured I'd give it a go - had a spare lead so ran it from the head unit directly to the amp, voila!
Still not sure why it's the lead or how changing amps had made this problem come out. One thing is for sure, I didn't think swapping an amp would result in so much work.
Hopefully that that's the end of that!
That's why I said it really depends on the sub 😂
16
Bonjour et bienvenue à mon ami d'outre-Atlantique! Need a lot more info on what the goal is and what you are working with. What car? Did it come...
Hello back, For those who are also looking for a problem of sh*t bass, after such a long time of fighting, I come to a conclusion that the...
17
4K
"large crimping tool" hammer or hydraulic? Seat bracket bolts aren't good. The seat brackets are usually completely painted and so are the...
All that carpet will have to be ripped out and replaced. There is no other way around it to get it done properly. Seal both sides of the...
17
eas
eas
Ireland
Bumpin' Goalie
    Jun 1, 2024
    May 31, 2024
