From 3 10s to 4 12s
Dre20xl
I need help with a design. I'm tryin to fit 4 12s in a sealed enclosure in my hatch but, i don't want them to fire up, forword or directly to the side. My space comes to 36" wide 17.5" tall and 66" deep. All my designs had canelation flaws So i gave up on them. Can someone please help me?
You have a ton of room. You could go to a 7th order bandpass and just see ports!!! I would think any bandpass design could hide the subs completely. You just need a good formula to design the box correctly.
this would be nutso just 4 6" ports firing forward or rearward
"i don't want them to fire up, forword or directly to the side."
so what then? angled baffle? down firing is you only direction you could fire, there is only up, front rear or side to fire the woofers.
fire the $hit up or toward the trunk..( Waste of thread )
I drive a ford probe witch is a 2 door hatchback, with the subs firing up they sounds shitty to me. as easy as it would be to just fire all 4 up i don't want to money and time. now can someone help me or design a box for 4 rear firing 12s that will fit the measurements 36" wide, 22.5" tall and 66" deep or is it not possible?
umm i would say impossible because u need like 50 inches wide
u only have enough to barely even get 3 subs if that firing back unless if possible u could not make the box as deep and angle the front like a v
you know what i am saying so 2 subs on each side and angle the box like a v
I'll be useing JLW0 4ohm and i listen to rap mostly and a little rock
How can you not like ported box's?? They're "better" for rap.. To each his own I guess //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
Dre20xl
Dre20xl
Spotyslvania, VA
tooloud4tv
