Farkel
My Rockford P450.4 amp finally came in, and I was wondering what the frequency dial is for?
It has LP - AP - HP settings and then above it the dial which goes from like 0hz - 400hz... how exactly do I set that?
Also, component speakers should be High pass and Subs be Low pass, correct?
On the amp, it has the B+ power wire slot and then next to it a slot called REM, what exactly is that and do i need to use it? thanks
