free simple box designs.
2 15's
sub back port back
tuned at 47hz
49" wide X 19" tall 32"deep
Im gonna throw a twist in for ya.....try to make it two layers all the way around and 3 layers on the baffell...... Also a HUGE port on the left side of the baffel. Thanks
2 15's sub back port back tuned at 47hz 49" wide X 19" tall 32"deep Im gonna throw a twist in for ya.....try to make it two layers all the way around and 3 layers on the baffell...... Also a HUGE port on the left side of the baffel. Thanks
//content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
48" wide, 15" front to back, 26" high space, want around 9 cubes ported to 32hz for an 18" Fi Q, slot port, port up? I guess? if you have any info on port layout please tell, thanks.
a box .75 thick would only be 8.9 w/o port or sub. with those dims.... either the box will be smaller than you want or it needs to have more room to play with.
Dual 12 box max dimensions 14h x 36w 24d. Double baffled with the subs and port forward and the port in the middle of the subs. Looking for around 4.5 ft^3 @ 38hz with as much port area as possible.
Thanks in advance
will get to you tonight, no time left in class today.
Thats fine, my other box is that size and i like it, when i said 9 cubes that was a loose number from Fi's website saying 6-10. Those dimensions will work for me, appreciate it.
alright i can prolly get a well braced 7-7.5 cu ft box. ill take a look when i get home.
hmm dont see a model info under tools? im using the free dl is that makes any difference.
mucho gracious //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif do they look ok to you? haha no customers yet. just doing freebies, though i would like to get more adept and eventually charge for it. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif doing 2 boxes for some locals this weekend.
//content.invisioncic.com/y282845/emoticons/laugh.gif.48439b2acf2cfca21620f01e7f77d1e4.gif I'm not checking your math but they look to be fine to me. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
You might not have model info, I'm not sure. I bought the pro version of SketchUp 4 when it was owned by @Last, and I get super cheap upgrade pricing on every version including the 7th iteration. If I can be honest, there is very little changed between 5 and 7 //content.invisioncic.com/y282845/emoticons/laugh.gif.48439b2acf2cfca21620f01e7f77d1e4.gif
2 15'ssub back port back
tuned at 47hz
You're stretching the limits of someone's good graces. If you need a very detailed or complicated design, it's just inconsiderate to want someone who's doing free simple designs for people to take the extra time for yourself.
haha i didnt really mind i found it fun and challenging, however it took me some time....
eh no problem simple enough just more text, haha port and sub placement dont hurt me unles you need really low tuning and prot area is easy to find //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif working on yours now i guess, haha.
will have yours in 3rd block bell is about to ring now. looking at 67.5 sq in of port area. will include some bracing.
Thanks bud
Sub up port back. Single 15. Dims, 40 wide, 16.5 tall, 17 deep. about 4 cubes after port displacement. 37 hz with 60+ in of port area. Not all that simple lo.l I think I have a design but would like a backup source
kk got it done, uses all the outer dimensions you listed, should be ~4-4.05 cu ft after port and sub(depending on sub)
40w 16.5t 17d 67.5 sq in of port. 2 45s both 2 inches long. 3 edges of port roundover(if you have tools to do so.)
top and bottom are 17x40
left and right are 15x17
front is 34x15
back is 38.5x15
port 1 is 11x15
port 2 is 9.75x15
and a brace as close to center without interfering with sub/port
6x 15
marcotheclepto
marcotheclepto
United States
ktraughb
